OK heres the deal bike was running fine went to start it the other day and got a back fire now it just cranks and will not turn over..
it has gas the fuel pump does come on and the kill switch is on
any ideas?????? thanks in advance
Try opening and holding the throttle at 100% as you hit the starter button, and let it crank for about ten seconds, release starter button, pause, then start as per normal procedure (i.e. no throttle). Hope this helps. :thumb:
If you cranked.... then got a back fire
Chances are..... Fouled Plugs......... I can almost make for certain
If not it might be a Battery that is not putting out enough cranks and causing back fires or it could be a combination
I just had that same problem with my friend Joes bike... Just wouldnt turn over... Would sputter here and there but just wouldnt start up. :idunno: I finnaly had to hook to the car battery and just cranked it for about 10 minutes off and on throttle and no throttle... I stopped shook the bike back and forth and side to side and then it just fired up like nothing was wrong :idunno: Not sure if that had anything to do with it but; OK :thumb:
