1 - 15 of 15 Posts
Any help is appreciated. Took the bike apart and put it back together. When i start it up it immediately stalls. Now if i start it and stay on the throttle for 5-10 seconds it'll idol just fine EXCEPT the FI indicator comes on and the red light on the dash lights up. HELP!!
What does "took the bike apart" mean exactly?
Did you reconnect the airbox sensors and vacuum hose?
I forget the name, sorry, Blade may be able to help out, but that little black box normally screwed to the air box, has 1 vac line running to it. I beleive that wont let the bike keep running...
Ill double check triple check if all is hooked up right.
"Took apart"... the tank,air box, changed the plugs,back together. I must admit as i was putting it all back there were some places where i felt there should be a hose. Is there a diagram or template i can look up? Thanks guys,I've been anxious to get this thing on the road.
The manual would be your best bet for diagrams.
Will that keep it from running altogether? Because the bike stays on,as long as i stay on the throttle for the first few seconds initially.
Discussion Starter #13
That hose was unhooked so i hooked it up,put it back together and....battery was dead lmao. I cant win:thumbd:
Discussion Starter #15
Just wanna thank chris and blade for the help,the bike is runnin good,no lights,just gotta paint her and immmmm gone!
1 - 15 of 15 Posts
