1 - 20 of 21 Posts
front rotors - 100
rear rotor - 25
headlight - 175
fuel pump - 95
forks - 250
bottom triple - 100
front calipers w/ lines - 100
rear caliper w/ line - 25
passenger pegs - 40
airbox - 30
clip ons - 35/ea
clip on controls - 45/ea
speedo/tach - 150
subframe - 100
front master - 80
rear master - 25
headlight/fairing stay - 95
ecu - 100
headlight harness - 35
main harness - 70
rear wheel - 120
front wheel - 225
lock set - 110
rearsets - 75/ea
radiator - 120
throttle bodies - 80
stator - 80
clean title frame - $900
PM me for plastics or anything else not listed. Motor will be sold as a whole or parted. The motor had tranny issues and I had a buddy put a new tranny in but there is something not installed correctly. It goes into first and neutral but won't go into the higher gears. Motor runs fine and replacement tranny came out of a good motor. No grinding etc, just need to fix something with the selector or forks, or drum, I don't know, I don't do motor work.
How much for the messed up engine? Are the cases good and not broken?
Oil pan? I don't know if your to the point of parting out yet or not but mine the right side fairing bracket broke in my wreck...
Just let me know thanks!
1 - 20 of 21 Posts
