1 - 2 of 2 Posts
I'm new to this site, and I need some help. I recently picked up an 02 cbr954 as a new project it was in rough shape when I got it a wireing nightmare just random cut wires every where. I've got all of the wireing fixed or replaced as of now and i have been able to ride it. seems to run great lots of power throughout. but the issue I'm having is at a steady speed normaly around 75-80 it seems to just loose all power like I turned the key off, but if I throttle it up a bit the bike comes right back to life. I'm not sure what this means and the only conclusion I can make out of it might be the o2 sensor, because its just sitting in the battery tray(no place to put it due to a different mid pipe) I reallize it can be eliminated and i plan to. just trying to get some other oppinions on the subject, any ideas would be greatly appreciated.
Can you weld? Or do you know someone that can? That would be my first option. Find a nut that fits the O2 sensor and drill a hole in the pipe. Weld the nut in and give it a shot. Worst that could happen is it doesn't work and you have to thread a bolt in the hole to fill it.
1 - 2 of 2 Posts
