1 - 14 of 14 Posts
i just picked up a 03 954 , the bike has 8500 miles , the bike is only firing on the middle 2 cylinders .. im sure there is 1000 possibilities , but where might i start , i know checking the plugs , gas , coil packs , but is there something somewhere else that maybe it coul be ???
thanks in advance Jeremiah
you say it's only firing on 2 cylinders, do the other 2 cylinders have spark?
If not I would check the ignition coils and, if still no spark, you may have a ECU problem.
if you do have spark, but it's not firing, i would check the injectors, and again the ECU.
the attached document should also help.
the previous owner claimed that when he rode it it missed a little then opened up , and that he replacedthe plugs , but hasn't ran even a full tank of gas through it yet ...im thinking of draining the gas and putting new gas in there... he also stated something about the tip over sensor was full of water so he bypassed it ??? if the sensor is bad could that also be a problem ??
Do you smell raw fuel? If two cylinders are not firing and the injectors are working, you should smell raw fuel. Bad fuel should effect all cylinders. Also. the tip sensor would cut off spark to all cylinders.
It is not the bank angle sensor; it cuts fuel to prevent a fire. Cutting fuel to two cylinders would not prevent a fire. I would also get a new sensor once you get the bike sorted out.
Check spark and the plugs first, then swap injectors around. See if the issue stays at the cylinders or movies with the injectors.
check the compression. if you dont have a compression tester, swap the coils, plugs and injectors from the working cylinders to the non working cylinders and see if there is a change. if there is no change then you have an engine problem.
if u have spark and fuel going to all 4 cylinders, crack the throttle open just a bit and see if all 4 cylinders all fire. I had an issue with the motor in my dwarf car having the trottle plates closed to far and it was choking off 2 cylinders until i back the plates off a little bit.
Ask the guy if he added a fuel system cleaner to the gas, I would definitely drain it anyway and start fresh then run it for a while at low engine speeds and see if it clears up. I once added some to mine to help clean out some old gas trying to avoid the drain/refill and must of added to much, it ran like bootie for a good while, backfiring, sputtering etc. till the stuff worked it's way through, it ran fine before I added it. Allot of that stuff is heavier than the gas and will settle to the bottom, causing the bike to run on it only. Like everybody else said also check the spark. Also check and make sure you have no vacuum leaks or air leaks at the intake. So many things it could be :confused: Good luck sorting it out. Let us know if you find it.
you may have already done this but I had an issue on my old bike where it was only running on two cylnders and the thing was backfiring too. Guy who I got it from for a really good deal said his kid was washing it and he might have gotten water in the tank. On further inspection he did a spark plug change and put two of the wires on the wrong cylinders. You might want to check your plug wires and make sure they are on correctly.
Had a cylinder not firing on my 02 954. Thought it was the regulator, turns out it wasn't. Pulled one plug at a time, grounded it, and cranked the engine with the fuel pump unplugged. When looking closely the plug was sparking, but the spark was going to the threads, not to the electrode. The insulator was cracked. Don't know if it's all that common with bikes, but I have had it happen to a lawn mower. This plug only had 3K Kms on it, was probably dropped during shipping.
It's a quick cheap test. If you're going to try to diagnose any further electrical issues/sensors get a manual. It gives the procedure and voltage/resistance you should see at different places rather than switching components. It's a lot easier to measure the resistance of a fuel injector than pull the rail off swap it to another hole.
1 - 14 of 14 Posts
