1 - 20 of 20 Posts
Discussion Starter #2
Re: 4-07 1000RR Mega Thread (Power up Kit, Sharkskinz, Ohlins, Galfer, etc)
Ohlins Titanium Spring - $300
Fits NON-TTX Ohlins Shocks. Sprung for lightweight rider. ~150-165lbs
Engine Building Kit - $2000obo
Will not part out. You want something in the list, buy the whole thing and part the rest out. Kit includes the following:
HRC JSB Spec Cams (Brand new)
Ten Kate Pistons (Used for 400 miles)
HRC Springs (Used)
Ferrea Competition Valves
Cams:
Pistons:
Valves:
Galfer 320mm Wave Rotors - $315 shipped
Little use. Used lightly on the street for Sunday joy riding for about 1000 miles.
Current thickness - 5.31mm (I think new they are around 5.5mm)
Minimum Recommended Thickness - 4.5mm
Sharkskinz Supersport Tail - $225 shipped
In near mint shape (in the pictures, there looks like some damage, but it's just some weird flash glare), this tail was painted with a custom dark red metallic on black. You can't see it in the photos, but get the tail out in the sun and it pops. Tail currently has a functional tail light for street riding; however, two holes were drilled in the tail for track riding (lap timer).
Gold Carbon Fiber (real) Front and Rear Huggers - $175 shipped
Great condition, no cracks or missing tabs.
Barnett Clutch Kits - $100 each
Includes Springs, Fiber plates, and Steel Plates. I oiled one set up when I was going to install a set into a friend's bike but he ended up not wanting to do the install because he found a new bike and sold his. Both kits are brand new tho.
Stock 2006 Shock - $85 shipped
Pulled after about 800 miles. Thing looks brand new.
Rear shock off my 04 - $30 shipped
Hyperco Spring - $50
Spring would work great for a 250lbs rider.
Ohlins Spring (like new) - $80
Rear Rotors (three available) - $85 shipped each
Flasher relays - both brand new, one without packaging - $20 shipped each
Tank Panels - $25 shipped for a set of 4. Multiple sets available
Clutch line - $15 shipped
Chrome Clutch Cover with mounting bolts (two covers available) Brand new! - $40 shipped
Blue and Yellow Tank Shelter with Carbon Fiber Inserts
Great Condition. Comes with CF look tank pad. Will not part out the inserts, they are epoxied in place.
$160 shipped
06-07 Candy Phoenix Blue Lowers (some heat damage...but looks great at 50mph or 50 feet away!) No cracks or missing tabs - $100 shipped
06 Candy Phoenix Blue/Pearl Yellow Tank with light scratches on right side - $100 shipped
scratches:
04-05 Red and Black Tank with minor marks (should buff out) - $125 shipped
Great condition 04-05 Lower Right - $100 shipped
Gutted intake (like a CF intake, but without the hefty price tag and no issues modding it to fit. Bolts right up!) - $85 shipped
Rear Caliper Relocator
For 84mm brembo rear P2 Calipers.
$75 shipped
do you still have clutch cover, and paypal
clutch cover gone, srry. Relocator bracket also sold. Everything else still available.
So the power up kit has only the pistons/valves used? Why are you selling it? Can you tell me a little more about it? Interested.
[email protected]
Who cares why he's selling it? :rolleyes:
Christ, I get so tired of that stupid question. Why does it matter one wit?
Obviously he doesn't need it anymore.
I've sold a ton of used stuff, and the only people that ask me that are the tire-kickers that never buy anything anyway. Sheesh...
bumpski.....and lol @jondog9 hahahha
chrome clutch covers gone as well as the caliper relocator.
Dan Kyle / HRC Full Race ECU 04/05 - $350 shipped
Hunter Orange Fairing Stay - $120 shipped
Hunter Orange Aftermarket Stator Cover - $120 shipped (OR $200 shipped for matching Fairing Stay and stator cover)
Has small mark on it (pictured)
OEM Stator Cover - $50 shipped
Small marks
Rectifier - $40 shipped
4 cell Speedcell Battery - $80 shipped
Dynojet PCV - $210 shipped
Bazzaz GP Shift Quickshift Sensor - $200 shipped
Bazzaz shipped me a new head unit and sent a newer quick shifter with it when replacing my broken head unit so I have two quick shifters now.
Discussion Starter #13
Sharkskinz Supersport Tail - $200 shipped
Metallic Dark Blue-ish Black OEM Honda Seat Cowl (some scratches) $50 shipped
$160 shipped
Near mint headlight. Has all tabs! - $150 shipped
Riders seat - $50 shipped
Discussion Starter #14
Subframe:
Rear brake with lightened bracket - $50
Rear brake with bracket (x2) - $45 shipped
White Aftermarket Clutch and Rear Brake Lines with purple banjos - $50 shipped
Blue Aftermarket Rear Brake Line - $35 shipped
Heat Exchanger - $40 shipped
Race Upper Harness (x2) - $40 shipped each
Blue Lightech Keyless Gas Cap - $80 shipped
OEM Horn - $20 shipped
Oem Shock Linkage (x4) - $40 shipped each
Discussion Starter #15
Radiator Brackets (x3) - $20 shipped each
OEM Rotors - $35 shipped each
Wave Rotor - $100 shipped
Tank Inserts - $15 shipped each
Upper and Lower Fuel Rails - $30 shipped
Spiegler Aftermarket Black Clutch Line - $50 shipped
Kill Switch (x2) - $25 shipped each
Steering Dampner Mount - $20 shipped
Axle Adjusters - $15 shipped
Discussion Starter #16
Trunk and Gas Cap Lock with one key (no ignition) - $80 shipped
Ignition and trunk lock set with two keys (no gas cap) - $80 shipped
Ignition Lock with one key - $60 shipped
Trunk and Gas Cap Lock with one key - $80 shipped
Stock Passenger Rear Pegs Mint Shape - $50 shipped
Turn Signal Flasher Relay - $25 shipped
Stock Rearsets (need pegs) - $40 shipped
Radiator Fan - $40 shipped
Sprocket Cover (x2)- $30 shipped each
Axles - $20 shipped each
Aftermarket Reservoirs - $25 shipped each
Side Inserts - $30 shipped
Right Side Rearset (needs peg) - $30 shipped
Discussion Starter #17
Rearset Heel Guards - $20 shipped
OEM Stock Levers (light rash) - $20 shipped
OEM Stock Levers (clean) - $35 shipped
Stock Rear Brake Reservoir - $20 shipped
Block Off Plates - $30 shipped
Kickstand (with wiring) - $25 shipped
Kickstand (no wiring) - $20 shipped
Sato Rearset parts - $25 shipped
Vortex Rearset parts - $25 shipped
Stock Brake and Clutch Master cylinders with Aftermarket Adjustable Levers - $200 shipped
Clear Stainless Steel Aftermarket Rear Brake Line - $30 shipped
Galfer Rear Brake Line Kit - $30 shipped
Discussion Starter #18
OEM Clutch Slave (x2)- $20 shipped each
Gilles Shift Support - $100 shipped
Cush Drive Rubbers - $20 shipped
OEM Cush Drive with Aftermarket Sprocket - $50 shipped
OEM Cush Drive with Aftermarket (Renthal) Sprocket - $50 shipped
OEM Cush Drive with Aftermarket (Red) Sprocket - $50 shipped
OEM Cush Drive with Stock Sprocket - $50 shipped
Upper Triple Clamp - $50 shipped
Brand New Chrome Stator Cover - $50 shipped
OEM Headlight/Tach Harness - $30 shipped
Radiator Hose Splitter - $15 shipped
OEM Black Shifter Lever - $20 shipped
Discussion Starter #19
Plastic Battery Tray - $40 shipped
Heat Shield - Free with any other purchase!
Air Funnels - $20 shipped
Front and Rear Axles - $20 shipped per axle
1 - 20 of 20 Posts
