I have an 06 1k, just bought a Jardane RT-1. I want to make sure I remove the HTEV correctly. I have done some serches, but still not clean of the exact steps in removal for my bike. Please help!
Dave
Remove the valve after taking cables off it. You must leave the servo motor connected and in place with the cables in it. Just tie the cables back somewhere out of the way and let them do their thing. If you remove any of those other items, you'll get a F1 lite with a code.
The servo on my 929 stripped its gears so i just pulled the whole system out motor and all. Its not an issue if you dont mind an FI light on. If you dont want red then do as denzee said and just remove the cables from the valve while leaving the servo intact.
