Anybody put HID's on the 08 and newer 1000RR?? If so how hard was it and where did you hide the ballast? I'm looking to do both bulbs.
Also pics would be a plus. :)
I tried doing a search and couldn't find anything on the newer bikes.
Thanks
Discussion Starter · #3 ·
I've already got a place lined up. But I was told it's a pita to mount the ballast that's why I asked here. I wanted to see if others have done it.
Thanks tho
It is a bit of a PITA. When I hooked up my buddies 07 cbr1000 we hid the ballast in the nose. It would probably be easier to remove the nose section and attach the ballast to the inside of it first using velcro or double sided tape. Once you have it mounted, loose fit the nose and make your connections. Then finish installing the nose. It would be a good idea to have an extra set of hands to hold it while you make the connections. There is alot of wiggling to be done.
