Hi all
Need some help. I have a 04 1000RR with a micron full system, KN Filter and a PCIII recently installed with the 121-007Map.
However i have facing a problem when i ride to 8K RPM my bike starts lagging some what like a rev limiter set at 8K. Please let me know what could be the problem is it common that this bikes come with a 8K RPM limiter initialy ? or any changes have to be done.
Thank in advance
Regards
Tabrez
Either the MAP is not loaded properly, or there is something wrong with the file. Start by reloading the STOCK, 121-01(?) file and see what happens before going further.
Agreed. Either the map is corrupt ( totally incorrect values that cause it to not run ) or its just WAAAY out of tune, so bad its causing a misfire. The Power Commander does not have rev limiter control.
Thank for the reply,
I have checked loading the Stockmap and everything is working fine, but i had downloaded the map of my spec from the PC site, and how can that be wrong, even if its not matching there from where should i get the map ?
