1 - 13 of 13 Posts
Hello from Sweden
I recently bought a 929-01 and wonder if there is any 16" front wheel that fits this bike without too much hazzle?
Preferrably without having to change disc and brakes.
That was my thought too. I'm sure there must be a good reason. I'm sure @IanDoohan will chip in later because I think he, and a couple of others on here (Gunk?) have done the opposite, i.e. the 17" wheel on the earlier models.
I'm fairly confident on the 929 though, that there'd be a myriad of problems not only with spacers, but also with the caliper mounting positions sitting the calipers to high leaving no form of adjustment - unless they're packed out with washers. And then, of course, comes the steering geometry!!
Wow! This a new one. I would
say the most difficult aspect would be getting a set of 330mm rotors with the older bolt pattern to match up to the 16” rim. Form there, it’s just a matter of spacers and a bearing swap to accept the 25mm axle from the 929. Probably won’t be able to use dust seals after that, but unsure.
I would love to see if someone has done it, and what the benefits would be. I can’t see any TBH.
The answer to "why" is that i would like a more down tilted riding position, like on my ZX7R.
Lowering the forks on this bike is not good on these, i´ve heard.
With the greatest respect, how the heck would you notice a half inch or 12.7 mm?
Heap of money, and that's before you even do a tyre search! You may be better just putting on a '60' profile tyre (instead of the '70' and try that for starters.
Another alternative is to drop the clipons down the fork tube a bit, making sure you leave clearance within the fairings.
Get a lower set of racing clip-on handle bars and drop the triple clamps 5mm. OR, shim/raise the rear shock.
Those options cost nearly nothing and will net you a better handling bike than a Frankenstein front end.
AND ADD A STEERING DAMPER 👍🏻
- To use other tires profiles is one option. Don´t know how much that would do though? Lower profile in front and higher rear...do you know how much that would lower/raise approximately?
Drop the clipons does not change the "tilting" of the bike, just the tilting of me : )
- I read in a forum somewhere that dropping the triples is not a good option to lower the front on these bikes? Don´t know why... I´ve done it on my ZX7R, and on that bike it was a good "mod" for handling.
Clip-ons just lower the pilot, not the bike.
The steering damper - is that necessary on these bikes or only when lowering the front/raising the rear?
I suggested the clip ins to make it “feel” like the front end was lower. Still having a hard time determining what your ultimate goal is.I haven’t heard that dropping the triples is detrimental to the 929, but of course I haven’t been researching it either. I’ve done it in all my 900’s (not 929) and have had no ill effects. I suggested the damper for the guess that lowering the triples May present the more likelihood of a tank slapper.
Drop the triples and ride it. Form your own opinion on how it rides/handles.
- How much did you lower the triples on your bike? I might go that way.
1 - 13 of 13 Posts
