1 - 2 of 2 Posts
Hi all,
I am new to the forum. I need some opinions! A friend of mine is selling a 77 CB750 Hondamatic for 1500 bucks. It's in fair condition, not bad of shape considering how old it is. I did some of my own research on "Hondamatics" I love old Hondas. Is this a bike worth buying? I think it would be neat to own.
I saw the bike in person, everything works, signals, lights etc. The only thing is that it has a rough idle. I touched all four headers quickly after it idled. One was cold, so I'm thinking the carbs need some cleaning.. Could it be something else causing the problem? :idunno:
Some help would be great! Thank you!:smilebig:
Hi all,
I would agree that the carburetor is probably blocked.
Off the top of my head the only other problems I can think of that would cause one cylinder to run cold are loose/bad plug lead, loose/bad plug, valve clearance too tight or bent/burnt valves or missing valve adjuster screw, air intake leak, broken ring, holed piston or bent/broken rod. All are easy to check for.
1 - 2 of 2 Posts
