Working on a 1984 700 Magna. Bike will fire and run for about 2 seconds and die. I have completely gone threw the fuel system: drained fuel from upper and lower tanks, cleaned tanks, replaced fuel lines, replaced fuel filter, bench tested fuel pump, removed and completely disassembled carbs, cleaned, blew out passages, re-set float heights to 7.2mm (.283"), re-build kits, tested floats for cracks, sync all four carbs. Re-installed everything. Bike still has the same issue. I have checked for spark and it looks good, but spark plug is wet with fuel. Seems like when engine fires it imedeitaly stops spark/firing. Do these bikes ever have issues with the ignition control units. Any help that would get me in the right direction to fix this problem would be great. Thanks
Working on a 1984 700 Magna. Bike will fire and run for about 2 seconds and die. I have completely gone threw the fuel system: drained fuel from upper and lower tanks, cleaned tanks, replaced fuel lines, replaced fuel filter, bench tested fuel pump, removed and completely disassembled carbs, cleaned, blew out passages, re-set float heights to 7.2mm (.283"), re-build kits, tested floats for cracks, sync all four carbs. Re-installed everything. Bike still has the same issue. I have checked for spark and it looks good, but spark plug is wet with fuel. Seems like when engine fires it imediately stops spark/firing. Do these bikes ever have issues with the ignition control units. Any help that would get me in the right direction to fix this problem would be great. Thanks
Will it continue to run while you spray starter fluid into the intake?
If you clip a timing light on each plug lead you will be able to see if the coil is firing.
When you re-set the float levels were they very far out of spec?
2 of the floats were a bit out of spec. I am sure it is not a carb. related problem as fuel is getting into the combustion chamber and when you pull the plugs, they are slightly wet. The carbs are not flooding either.
Found the problem...!!! Bad fuel pump relay...!!! Would work intermittently.
Related Threads
1.2M posts
83.2K members
Since 2003
A forum community dedicated to Honda Fireblade motorcycle owners and enthusiasts. Come join the discussion about performance, racing, modifications, classifieds, troubleshooting, maintenance, and more! Find conversations about your favorite CBR 900 or 1000 series RR models.
