1 - 1 of 1 Posts
Is anyone aware of fuel delivery problems on f2's? I recently purchased a 92 F2 and I am having trouble getting it to run correctly. The bike starts fine (the first time) but it's starving for fuel in the upper rpm range. Then when you come to a stop the bike will cut off. When you try to re-start it sounds like it's out of gas, then it finally restarts but does the same thing over again.
Does this sound like there is a problem with the vacuum controlled fuel pet cock? Maybe a cracked vacuum line? Help! Thanks.
1 - 1 of 1 Posts
