1992 CBR900RRN Restoration
1K views 5 replies 3 participants last post by  chobes
#1 ·
Afternoon all,
A few months ago I bought a tired 92 Blade as a bit of a resto project to put back to correct period (it has foxeye front end which i presume was fitted post accident).
I'm starting to put back together so thought I'd start a thread for questions/general interest. First question is, I've fitted the correct bracket for twin light fairing, I've trial fitted the lights and fairing but it appears to sit too low for the wing mirror frame. Does the bolt on the front of the speedo bracket bolt onto the lights, and if so what does the fairing drilled hole in the centre of the fairing bolt to?
Pics for reference.
Automotive lighting Automotive tire Plant Motor vehicle Hood
Automotive tire Motor vehicle Electrical wiring Gas Automotive exterior
Motor vehicle Automotive tire Automotive exterior Gas Rim
See less See more
3
#6 ·
There are two fairing stays that need to be changed out - the one you've already changed where the mirrors bolt on, and the other one where the gauges/clocks mount. '95 and later, the gauge/clock mount is much lower where the front fairing positioning/setting bolts attaches.
