1 - 14 of 14 Posts
Hey all, I'm back again and looking for people who have experienced what I am about to desribe and their possible remedies. My '95 CBR900RR will ride fine all day long, then I'll let it sit for awhile, only to get back on it, ride it for a bit and then it bogs out, sputtering and then dying and I have to wait for it to cool down and then it will start right back up again. The last time this happened, which was this everning after riding in 100 Degree weather down here in south Texas most of the day with a full tank, I pulled over into a parking lot and checked the fuel lines and filters, and noticed one of my filters between my fuel pump and the carbs was way low so I popped the tank and let some air in thinking the bike may have vapor locked (but no whooosh sound), waited a bit and tried to start it and nada. Then I put the choke on all the way and it came to life, only to cut out and die when I took the choke off. After sitting for a few more minutes I decided to twist the throttle to overflow the carb bowls and then hit the switch and bang, she came to life and ran great after that. After getting her home I proceeded to check the battery voltage, fuel cap, lines, fuel pump and filters and the tank vent hose and found nothing out of the ordinary. I'll also add that I have a new fuel petcock so I wouldn't think that was the culprit, unless it's a lemon and needs to be swapped out again, and all the fuel lines are new as well. Also, the bike cuts out when I get just past a 1/2 tank of gas... so I'm thinking vapor lock, right? Anybody ever had this problem and what did you do to fix it? I'm thinking some heat shield for the underside of the tank and some tin foil insulation or something for the fuel lines? Any ideas or experiences on this stuff? Thanks to all in advance.
Chris
jonate - I thought such as well and checked all the lines, all good and tight. I riode out this morning and then parked the bike while at work and came back around 2pm and started it up and then got about half way home (10 mile trip) and she did it again, so I pulled over into a gas station and filled the tank all the way and waited for about 10 minutes and then took off and she ran fine. This is annoying. Also talked to a Harley rider at the gas station, he mentioned something may be arcing across, like ignition, coils or maybe the module, those are the next things to check. Thanks for your reply.
I can't say that I've lived what you're going through, but it sucks that you're having problems. Granted the 900 has a fuel pump, but I'm wondering if it's as something as simple as a venting hose.
I'm pretty sure the 95 is somewhat different from my 99. According to the fiche, you should have two hoses leaving the bottom of the tank. One is a breather hose, and the other is a drain hose. Make sure that breather hose doesn't get kinked as you lower the tank in place.
If you changed your fuel filter, was it a stock replacement?
Other than that, I suspect that your fuel pump "might" be on it's way out.
Sorry man.
Pull the hoses and blow through them, make sure nothing is blocked or kinked when you put everything together...
The fuel pump must be working to an extent as it does work, but for some reason it seems like there is starvation of fuel? Check the filter like paul said and see if its clogged...
Let us know how it gets on
Thanks to all who replied... fuel pump was sputtering out, and the relay was bad as well. Temporarily removed the fuel pump and am running gravity feed from the tank to the carbs with an inline Goldwing fuel filter, seems to be running fine = smoother and reliable. One question though about running it this way... anybody ever done this? By physics alone I know I can get away with riding it this way until I can scrounge the $170.00 together for a new fuel pump, but has anybody on this site ever done this as well, even for just a little while... and if so, what were your results?
Thanks all!
Chris
I believe LoopyLee had to do it, why not drop her a message and ask?
I have experienced the same problem with my 95 CBR900RR. The bike less than 5000 miles and I don't ride "all out." Quick, rapid accelerations here and there, but nothing too extreme.
I first experienced the situation when riding down a county road. I was able to get the bike started and running pretty well, engine temperature was right, the idle was at the factory recommendation of 1,500 RPM's, and I put in 92 octane petrol for it (recommends 86 octane). Anyways, when I start riding, in about five minutes, I keep my eye on the tachometer and see it decreasing like it would when I run it with the fuel valve off. It seems like it is lacking fuel, but I cannot figure out what the problem is. The first time it happened, it died on me at about 45 mph, and I tried to start it up again (electric and roll start), but couldn't. By the time I come to a stop, the battery died on me.
At first I thought there was something wrong with the electrical system, but found out it wasn't (good battery, etc...). I had a battery charger on it and tried to start it up, cranking it a lot of times, but I didn't smell any gas at all (usually I can smell fuel if I keep trying to start it up). I talked to my friend and he says it might be something wrong with the fuel pump or something stuck in the fuel line.
I took off the tank and start "tinkering" with the fuel lines, put everything back together, started it up and ran it for 10 minutes before I took it to the street. After a 3 minute ride, it died on me again, seeming to lack fuel. I was rolling down hill, fortunately, and used the electric starter (took like 4 or 5 tries) and got her going. Came to a stop sign and it was still running good. Drove it home, got off the bike, and sat and stared at the perfectly running motorcycle.
What could be the problem? It runs, dies, runs, dies...
Loopys ran fine with the gravity feed..
altho.. it did suffer slight fuel starvation at high revs.. felt like it had restrictors in at high revs... but it happily ran like it for the 2 or 3 weeks till the new pump was fitted
Also remember the carbs are sat higher than the tap .. so you need to make sure you,ve got plenty of fuel in the Tank:thumb:
This all sounds like the problem we had with loopys bike....
... checked the fuel pump twice both times it was fine according to manual, after a week of contantly having to pick loopy up/or jump start the bike, we rechecked it... seemed fine.. then stopped.. then ran again:crap:
Everybody said the fuel pumps either work or don't....
& just as loopy was striking a match ready to torch the thing .. we discovered That's B0LL0x!!! they do develop intermitant faults:(
Sounds a bit like my coil on my consul... They said it either worked or didn't... Well I can tell you under load she was a pig (but she was still working)
Try and eliminate factors one by one (starting with the cheapest)
I ran gravity feed for a month with no problems. I had to eliminate the filter as it wasn't flowing nearly fast enough. I still got the full range out of the tank. The float bowls are lower than the lowest part of the tank, so you will get most of the fuel out of the tank.
I bought one of these off ebay. It fit perfectly, took 5 min to put in, and works great.
You problem sounds exactly like mine when my pump died, on a road trip 100 miles from the nearest town.
eBay Motors: Honda,Kawsaki,Yamaha,Electrical Fuel Pump,CBR,ZX,FJ,FZR (item 280269431172 end time Oct-20-08 21:28:28 PDT)
1 - 14 of 14 Posts
