Hello everyone. I recently picked up a CBR for 400 from a co worker. He had it sitting in his garage for quite a few years. There are parts that are missing. Seems as if someone took rear tire off and forgot to replace all the parts when they put it back on. The chain is gone as well as the rear caliper bracket (its on order). What is also missing is the spacers that go on the rear axle shaft I believe that are shaft collars but can be mistaken by the name. I will upload a photo that shows it. But in the service manual on page 13-0. It shows them as going next to the wheel. Being a machinist I can fabricate what I need. However the one thing I don’t have are dimensions. Is there any one who could help me out with this. Much appreciated it you can. Thanks.
Looking at Partzilla.com the brake side spacer is the same as a 93 900RR, and the chain side is the same as a 99 900RR. Of which, I have both. It may take a day or two, but I'll see what I have for spares to get some dimensions.
Thanks a lot... I was also missing the chain adjusters and just got done building a set .. i dont know what the guy who had this bike was doing with it but hopefully i will be able to get it back in running shape again. I will post pictures later..
thanks
I have bitten the bullet and ordered a rear axle with the spacers as well as the washer thing at the end that is under the nut..
I also ordered the Bracket to mount the rear caliper.. I will measure and draw (solidworks file) and post all dimensions for spacers for future reference
and while i was at doing all this for the rear tire I machined some chain adjusters
now all I need is time at home to be able to see how it all fits.. will have to wait a few days to get the axle and spacers , but not to worry there is a bunch of other stuff that needs attention
Should i start a post and keep track of everything that I fix and find wrong as well as parts that i make to replace parts.. As I said I am a machinist and have CNC and manual machines at my disposal
thanks all
thanks all
Ah phuck, I dropped the ball and forgot. Usually I’m pretty helpful around here :crying
Question. I can cannot get my bike to run Eddie even idle and it sounds like it's misfiring it my main question is is there a way I can bypass the TPS sensor
Go to introductions, post a bit about yourself and what you're working on. Then in the cbr600 section begin your own thread about your specific issue/question. I'm sure you'll get the answers you're looking for.
