1 - 11 of 11 Posts
I have a 900rr that I was going to build into a fighter, but due to the frame not having a title, and the upper engine case having a hole in it, I'm parting it out.
Pre-shipping prices, OBO!!
Complete front end (Forks, wheel, disc, axle, upper/lower triple, stem, brake calipers/lines) - $150 ------- willing to separate if need be.
Tank w/ no gas cap (no rust, small dents) - $45
Headlight (tabs OK, some scrapes) - $30
Cluster (Speedo, tach, temp, 19k miles) - $30
Rear sets (stock, bent rear brake lever) - $20/side
Transmission (complete) - $150
Crank w/ pistons (rods & all bearings) - $50
Clutch Plates (used, not abused) - $30
Wiring Harness (clean, coils incl.) - $40
Stator/Rectifier - $40
Rear shock (stock) - $30
Radiator (great shape) - $60
Starter motor - $20
Front master cyl - $10
Oil pan - $10
Rear end (swingarm, wheel, sprocket, axle, rear brake) - $100
I am interested in your tank and radiator..does that come w/fan.?? also do you still have the stock tail piece..? I also need the right side footpeg assembly and rear master cylinder if you have that. I'm located in Bremerton so no shipping required....oh and do you have the pulsar cover.? Give me a call.. Tim #360-204-6473 email [email protected]
Ok..I just read and old thread so I know you dont have the tail anymore but I definitely want the tank, radiator, right rear set, oil pan, and possibly the rear end...so give me a call 4sure. Thanks
1 - 11 of 11 Posts
