1 - 19 of 19 Posts
Hey guys -
First off, yes i did search for "fairing" or "Plastics" or "Interchangeable" and got nothing....
The project bike I am working on will need all new fairings. I have been searching on the interwebz and found someone that put 2004-2005 CBR1000RR fairings on their 1997 CBR900. I cant find the write up or the build progress so I am curious...
What other Honda fairings will fit my 1997? Is the front fairing with the light in it swap-able from 1998 to 1997 using the 1997 lowers?
Are there any other fairings that anyone knows of that just bolt on or go on with only MINOR modifications??
Thanks a bunch!
Tupp
Not many folks have swapped the fairings over, this guy put 08 fairings on and that a custom tail piece
Used race fairings as they come in two parts so its easyer to extend or move the standard mounting points to fit. I think you could make most race fairings fit like this but you would need some custom made brackets to pick up each mounting hole. You can of course fit 98 cbr plastics, i believe the sides pannels are identical so you could just add a 98 cowl to your 96-97 side pannels
I have a 97 and a 98 fireblade...
I want to do a hybrid of the two... I like the Front fairings from the 96-97 best with that cool ass headlight but I dont like the boxy ass end of the 96-97
I want to take the tail section from a 98-99 and put it on there with that tail light too
Also I have seen online where someone with a 97 CBR900 put the 2004-2005 CBR1000RR plastics on
Has anyone here done anything with different plastics/fairings?
This is supposed to be fireblade HQ... someone help me with this question...
Cheers
Tupp
I put an '08 fairing on my '97, not too difficult using a 'race' type GF fairing, cheap too. I had a lot of 'fun' cutting out the headlamp openings but you could use anything you fancy, Lambchops has suggested a couple of round projectors that would make that job a lot easier. I did some cutting and shutting to the belly pan but nothing too extreme and a Dremel makes light work of it.
BUT, although I am a bit pleased that I could make it all look reasonable..... I'm not quite happy with the overall 'look'.
The older 'blades seem to suit the more slab sided fairing designs, I'm probably going to change to an '04 type as and when my enthusiasm level rises again.
Just rumiaging through some old photos, came accross my CB450 outside our local meet, back in 1970, just thought I'd add it for old langs syne
Mght I suggest that that is a perfect photo to return to with each bike you own, or even the same bike every year would make an interesting study :)
For standard panels the lowers and mids from 92-99 fit, the top cowls all fit to the mids but need different clocks and mirror brackets, the inside panels are different 92-97 and 98-99.
It's reasonably easy to fit 929 tailpiece.
Thought about a streetfighter?
I have thought about a street fighter but personally I like the look of full fairings on bikes... Most of the time when I see a street fighter I think that it is just a cheap way out.
However there are some SUPER SWEET fighters that I have seen, with way more money and work in to them than it would take to piece together the plastics... however to the untrained eye it can look like someone has a cheap POS bike
jdugen - Do you have more pictures of the bike with the 08 fairings as you put them on? what is it about the '08 plastics that you dont like? Also can you put together a parts list and rough cost estimation for each piece? I am sure it is a bit more evolved than just buying the fairings....
Cheers
Tupp
Cheers
Tupp
I don't mind no fairings on slower bikes, but anything you're going to ride over about 140kph gets really uncomfortable in my opinion, due to the wind. I've ridden my 929, GSXR's and ZX6R (and others) without fairings and don't enjoy it much, compared to with fairings of course. It's hard not to enjoy riding almost anything, even when it hurts :)
Hi Tupp.
Cost of fairing, glass fibre replica, but, well enough made . £130 + £16p+p. EBay, quite a few on there. The Chinese painted reps look good at about £350 - £450 all in. They too use the simpler construction of all in one panels rather than the OEMs jig-saw puzzle.
Front bracket / hanger. £35, EBay again, a local (UK) supplier but probably Chinese. Indistinguishable from OEM
Headlamp unit £10 + £5 p+p (!) Seem to be a lot round at about £20 - £30.
Mirrors £18 free post. Used these as they have built in indicators. Not much use as mirrors as show more elbow than road. I'm looking around for ones that have a bend in to lower them a bit. Might just go for standard indicators on the front to widen the choice of mirrors.
Some cheap and cheerful decals £5
Had a big can of metalflake black in stock so thats what the bodywork got!
2 bits of ally strip to make up the fairing side mountings.
The only awkward bit was fitting the instruments. I did have a nice looking and small Chinese digital unit fitted, but it turned out to only display kilometers per hour. So, I had some clocks from a previous Honda build that fitted and connected fine, but were a bit too bulky to allow free bar movement. had to do some very judicious cutting and shaping to make them fit. A small digi unit would be my recommendation for ease of fitting.
Hope this helps
Cheers
Hi Tupp.
I'm chasing up fibreglass race fairings just now.
Is that £130 correct? Is that a full kit or just one piece?
I'm looking at close to $1000 for a kit.
... Nothing???
sorry man:crap: the reason no one really said anything. is because people ask that same thing ever other day:rotfl: so if you do a search.... you will see what others have done;)
:welcome: that's strange you don't like the 98/99 front??? make it like this!! the the last one is just one that I like:D
Discussion Starter #13
Thanks Tweezy!
I know what you mean with people asking the same thing over and over...
One of my pet-peeve too
I always search first and ask questions second
What yr plastics are on that?
Jdugen - thanks boss great info!!
Tupp
some more!
No worrie:) tupp! your a bike guy your in the right place!
I felt bad not not saying anything:-( I gave a huge post to the last guy with pic's and list of parts and prices!!
on what bike??? some have Gsxr tails and 98/99 cbr 900rr fronts, one with the front change so it has 04 to 06 1000rr lights and r6 tail!
some have 04-06 R1 tails and vfr swing arms!
I have seen them with 1000rr fronts and 954 tail! I have seen them with 1000rr tail! with 929 tails! 600rr fornt and tail! alot of them have 954 forks or 929 forks wheel!! some have 1000rr forks and wheel
the 98-99 fairings and lights fit! they look a lot better and work better!!! they cost alot thou!!! you can make the 08 cbr 1000rr race fairings fit, then put the light in!!! I have seen people use evey front you can think of!!! but if you want eazy!!! the 98-99 is the only one that is easy but it's not that easy!!! some info and pic's of other bikes!!! to fit the 99-98 front you need all this stuff
98-99 Headlight
98-99 Center position light
98-99 Fairing stay (you'll have to custom mount your gauges)
98-99 Mirror stay
98-99 mirrors
98-99 dash panels
98-99 windshield
98/99 upper inner radiator shrouds
98-99 lower center V
98-99 lower fairing panels (to mount the center V as it is taller on the 98-99 and meets up with the inner radiator shrouds
As you can see from the list above, none of your 95-97 parts are compatible with the 98-99 model, so this is more involved than when you first came here with your idea of what it would take. Good on your for asking the questions first before you attempt this conversion. It's not that hard to do, but you need the right parts.
you may all so want to change the tail too a gsxr tail looks good!!! so do the 929 and 954 tails! you can do those one's with your sub frame!!! made to fit!
Where did you get those comparison diagrams Tweezy there great?
Also like the bike you posted with the 98 race cowl with headlights cut out for the 05 blade, looks good! Next year I may be changing my fairings, not decided what to do yet may get the race fairing for the 98 (if i can find anywhere still making them) and do something with the lights like that.. Cabbie has also given me his custom fishtail rear end so that will be going on too :)
:D thanks
not sure where i got those??? may have been from another post:idunno: but when I saw them, I saved them!!!
Yea I really like that front!!! I have seen a guy do that with the stock 98 front too:cool: they just fiberglass it in! i was thinking about buying a old -05-06 1000rr front that the ears are messed up, cutting out the headlight mouts. then mudding that on to the stock 98 front???
what dose the tail look like? never mind i have a pic of the bike:rotfl:if it's his old one??? if it's that tail, i love it!!!
1 - 19 of 19 Posts
