Hi,
I have just replaced the original rectifier-regulator with a non Honda part and had the burnt out stator re wound. Does anyone have details of the actual circuit contained within the regulator-rectifier box.
I would like to know out of curiosity
I have actually found the motor to be smoother after this work or am I dreaming?
A word of advice: regardless if your rectifier-regulator has failed, apply heat transfer paste to the mounting plate as I found that mine was only touching on 2 small points. This would let the assembly run hotter and probably contributed to its failure.
Rick
Rick
