Evening guys
I'm going to be fitting a new set of tyres and rear sprocket this week.
As I haven't as yet got myself a workshop manual please could a kind fello fireblader post me torque settings for the following:
Front axle nut & pinch bolts
Rear axle nut
Rear sprocket nuts
Much appreciated :)
According to Mr Haynes..
Front Axle 60 Nm
Pinch bolts 22 Nm
Rear Axle nut 95 Nm
Rear Sprocket nuts 108 Nm
Ride safe
Evening guys
Rear axle nut
Rear sprocket nuts
Much appreciated :)
I presume your also fitting the front sprocket as well? I only say as I've always read, do both at the same time. are you sticking with the standard tooth size? I did last time, but fancy a wheelie machine the next time round...
Thanks lads much appreciated !
John the bike recently had a chain and sprocket set fitted just before I bought it, but i dont like the look of the standard rear sprocket so i'm fitting a Gold Rental. Gearing will be standard 42 tooth.
My other bike (Yamaha R1 4XV) has different gearing and your right it does make a difference.... but im sticking standard with the blade.
