1 - 9 of 9 Posts
Hi guys, I'm new to the forum but I have been riding bikes all my life. I recently had my transmission race cut due to second gear slipping. All the work was done by a guy who builds drag bikes. My first test ride ended after about 10 miles. I rode for 4 miles and I lost my clutch, after getting it adjusted i rode for six more miles before I lost it again. At this point, the oil light first started flickering and the last 2 miles it stayed on. I also noticed the temp reaching 240 degrees fahrenheit. I quickly parked it and haven't started since. Any ideas on what could be going on with my bike? Considering the cases were split to get the transmission out and back in.
What do you mean by "lost my clutch"?
The bike wouldn't move at all?
Has it got oil in it?
Are you sure it's the oil light and not the MIL?
Is the radiator full of coolant (ignore the reservoir)?
Have you taken it back to the guy that put it together?
What I mean by lost the clutch is that i could pull the lever all the way in and the clutch still wouldn't engage. I adjusted it and after about 5 more miles the same thing happened again and I had to keep going until I stopped. Im guessing its the oil light because it had the oil bottle above it. I'll have to check the radiator because i didn't look inside of it. The guy told me to bring it to his shop and he will look at it Monday. I just wanted to get opinions from other fireblade owners to see what might have happened.
To engage the clutch you let the lever out.
I think you mean you can't disengage the clutch to be able to stop?
You can change gears without using the clutch.
Have you checked the oil level?
Is it the original clutch pack or was it replaced?
Sorry, but yes I mean disengage the clutch to be able to stop. I know that you can shift gears without the clutch and that's what I had to do on the short ride back to my house. I checked the oil as soon as the light came and yes it was full. After I rode it back home I checked it again and it was still full. The clutch was replaced with barnett kevlar fibers and barnett clutch springs about 200 miles ago so I didn't feel the need to replace it again.
It just occurred to me, the clutch basket drives the oil pump via a chain and the oil pump drives the water pump. Since you are having clutch/oil/water problems perhaps the chain or drive sprocket has come loose.
I think you and the guy who worked on my bike are on the same track. That's exactly what he said may have happened and that is the first thing he is gonna check on Monday. Thanks bladeracer for all your help and i'll let you know how it goes Monday.
Took my bike to the shop today and bladeracer you were on the right track. Evidently the guy didn't even tighten the main nut for the clutch basket...when we took the cover off I could turn the nut with my hand. After tightening the nut and puttingn fresh oil, I rode the bike for 40 miles today with no problems or strange noises coming from the engine. My only question now is should I look for any long term problems that this no oil and no coolant for 2 miles could have on my engine?
1 - 9 of 9 Posts
