1 - 2 of 2 Posts
Ive got a '01 929RR and the engine will not turn. I thought it would be the battery but everything turns on. I even double checked the charge of the battery and it is fine. I just put the key in and try to start but I just hear silence. Any suggestions? Could this be a starter problem?
Is the killswitch off?
What voltage does the battery show?
Can you hear the fuel pump priming when you turn the ignition on?
Have you done anything with the bike recently?
More likely one of the kill switches I think. The starter relay doesn't draw much power so even a fairly flat battery will trip that.
1 - 2 of 2 Posts
