1 - 1 of 1 Posts
Hello people:
I built a two seater sand rail and used a 2001 cbr 600f4i power plant.The bike was a recovered wreck. it had sat un touched for three years.The brunt of the crash was on the clutch cover side. I extended the harness to utilize the factory controls and cluster.The problem is the engine half a$$ fires the plugs on ether and the injectors will not fire on the bike.I can make the fuel pump come on by touching a test light to the small brown wire with the black stripe.I have replaced the ecm,pulse generator, cluthch cover and the fuel pump.. Can anyone help?
1 - 1 of 1 Posts
