This bike was rescued from neglect, gone thru thoroughly, and with some upgrades, before being put on the street in summer 2016.
Work done: Front and rear calipers rebuilt and new pads, SS bolts and pad pins, braided front brake lines, MC rebuilt; New clutch cable, clutch inspected for wear and in spec but clutch springs replaced (Barnett); One throttle cable replaced; valves checked for clearance; PAIR valve removed and blocked; new BMC air filter; Rear undertail was hacked up so I replaced with a clean used one, painted, and aftermarket LED turn signals; Front wheel bearings replaced; Front forks rebuilt with bushings seals and Race-Tech Gold Valves and Hyperpro springs; Rear shock replaced with Elka 3-way shock; New tires in May ’16, about 1000 miles on them; New rear sprocket; Coolant replaced and coolant reservoir; Exhaust is stock, PC3 usb has been programmed for this exhaust. Oil and filter changed with Mobil1 motorcycle oil; Frame measured by GMD and is straight. UPDATE 6/10/17: new drive chain and fresh oil and filter.
This bike is a hoot to ride and is a great track bike. The suspension is awesome, you’ll love riding this bike.
I have suspension settings recorded for my weight (200 lb). Bike is turnkey, clear title.
Mileage is 33.6K - that’s 2240 miles a year. $4300. BRO. In Central MA.
VIN: JH2SC500X2M002287
