1 - 2 of 2 Posts
Hello Guys,
I'm having a rattle sound on the right side (clutch side) of the engine.
The sounds happens when is at idle and dissapears once the engine pass the 3k rpm's.
Here's a video :
https://vimeo.com/138147027
Ideas ? Thoughts ?
I disassembled the clutch cover and found everything in place, except that there's some play (backlash) between clutch basket gear and primary gear on the crankshaft. Here's a video showing it :
https://vimeo.com/138148665
Do you think that's normal or I should replace the entire clutch ?
Could somebody make me a favour and check if that happens on other bike ? You can check that easily by removing the oil fill cap and moving the clutch with your finger.
Thanks a lot guys !
I know it's an old thread but did you ever figure this out? I have the exact same problem with my F3.
1 - 2 of 2 Posts
