1 - 2 of 2 Posts
Specifications
Model: Honda CBR 1000 RR Fireblade
Year: 2006
Category: Sport
Engine and transmission
Displacement: 998.00 ccm (60.90 cubic inches)
Engine type: In-line four
Stroke: 4
Power: 169.50 HP (123.7 kW)) @ 11250 RPM
Torque: 114.50 Nm (11.7 kgf-m or 84.5 ft.lbs) @ 10000 RPM
Compression: 12.2:1
Bore x stroke: 75.0 x 56.5 mm (3.0 x 2.2 inches)
Fuel system: Injection. Dual Stage Fuel Injection (DSFI)
Valves per cylinder: 4
Fuel control: DOHC
Ignition: Computer-controlled digital transistorized with three-dimensional mapping
Starter: Electric
Cooling system: Liquid
Gearbox: 6-speed
Transmission type
final drive: Chain
Clutch: Wet, multiplate with coil springs
More details Consult a Honda repair manual.
Physical measures
Dry weight: 176.0 kg (388.0 pounds)
Seat height: 820 mm (32.3 inches) If adjustable, lowest setting.
Overall length: 2,160 mm (85.0 inches)
Ground clearance: 130 mm (5.1 inches)
Wheelbase: 1,402 mm (55.2 inches)
Chassis and dimensions
Frame type: Diamond. Aluminium composite twin-spar.
Rake (fork angle): 23.5°
Trail: 100 mm (3.9 inches)
Front suspension: 43.0mm inverted HMAS cartridge fork with spring-preload, rebound and compression-damping adjustability
Front suspension travel: 119 mm (4.7 inches)
Rear suspension: HMAS Pro-Link single shock with spring-preload, rebound and compression-damping adjustability
Rear suspension travel: 135 mm (5.3 inches)
Front tyre dimensions: 120/70-ZR17
Rear tyre dimensions: 190/50-ZR17
Front brakes: Double disc
Front brakes diameter: 320 mm (12.6 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Power/weight ratio: 0.9631 HP/kg
Other specifications
Fuel capacity: 18.16 litres (4.80 gallons)
Color options: Black, Candy Blue/Yellow, Red/Black, Silver/Metallic Silver
Comments: Model ID: CBR1000RR
1 - 2 of 2 Posts
