I just got done setting front fork sag on my 07 blade. I’m 170 lbs with full gear and needed to adjust the pre-load all the way hard to get 39mm of sag using the race-tech method that accounts for stiction/drag. Does this sound right for my weight? My riding style is aggressive street riding (at the right time at place, of course).
You should be able to get a stock bike within range at that weight. IIRC the stock springs should be fine up to 180lbs. I’m on 1.0 springs for 210 rider weight, GP Suspensions setup, 06 Blade.
Discussion Starter · #3 ·
I realized after fooling around with setting my preload that there is only a ~1mm difference in sag from about 10-14 turns from full soft so I took the pre-load out a couple turns just to soften it up without really affecting sag. Still managed to get 38mm of sag, not as low as I would like, but good enough for the streets I guess. I really like the preload a little stiffer; it allows me to turn into the corners much quicker with much more stability as well as increase my stability at super low speeds (u-turns, parking lots, etc.). I believe I set my rebound to 1 1/4 turn from full hard and my compression 1 3/4 turn from full hard. I’ll tell you, this has made a night and day difference. I didn’t realize how unstable my front end felt until I tuned my forks. Anybody putting off a good fork tuning should really make the time. This procedure has increased my enjoyability by 10 fold on the road. Can’t wait to upgrade to k-tech cartridges and springs next season!
