I cannot find the answer to this on a search (too many threads!).
Can anyone tell me please how much oil it takes to fill from the minimum mark to maximum mark on the dipstick on a 2008 'blade ?
i dont think your going to find a magic number on that one...just keep putting a little bit in...start the engine...let it sit a couple minutes and shake the bike a little...check again and insert more oil if needed...i never strictly go by numbers for oil in any of my vehicles...i check the amount that the factory suggests and i put that amount in and then i check the dipstick or glass and add or take away if needed...
Discussion Starter · #3 ·
Thank you, that is what I do now.I find the dipstick very vague, however. I am also impataint. If I knew for example that min to max was say 1/2 litre and the level was 25% I could put in 125ml ish and not worry. Hey ho.
