Triumph’s Speed Triple, first launched in 1994 and with sales figures fast approaching the 50,000 mark, is considered by its delighted owners as the best naked bike on the market and the ultimate in factory streetfighters.. And it just got even better.
In a virtually unheard of move, Triumph listened to its customers and modified the Street Triple in response to owner feedback, and while the bike looks almost identical to the original it now boasts a host of refinements. The 2008 model now sports, amongst other things, an LED rear light, a new sub-frame, Brembo front brakes, and anodised forks and handlebars.
New Features
High-spec Brembo front brake calipers and radial master cylinder
Restyled alloy multi-spoke wheels
Black anodised 43mm Showa upside down front forks
Tapered, anodised aluminium Magura handlebars
New rear sub-frame and redesigned bodywork
Redesigned radiator shrouds
Repositioned aluminium pillion footrests
Specifications
Engine Type: Liquid-cooled, 12 valve, DOHC, in-line 3-cylinder
Capacity: 1050cc
Bore/Stroke: 79.0 x 71.4mm
Compression Ratio
Fuel System: Multipoint sequential electronic fuel injection
Final Drive: X ring chain
Clutch: Wet, multi-plate
Gearbox: 6-speed
Frame: Aluminium beam twin spar
Swingarm: Single-sided, alumium alloy with eccentric chain adjuster
Front Wheel: Cast aluminium alloy , multi spoke, 17 x 3.5in
Rear Wheel: Cast aluminium alloy, multi spoke, 17 x 5.5in
Front Tyre: 120/70 ZR 17
Rear Tyre: 180/55 ZR 17
Front Suspension: Showa 43mm upside down forks with dual rate springs and adjustable preload, rebound and compression damping, 120mm travel
Rear Suspension: Showa Monoshock with adjustable preload and rebound and compression damping, 141mm travel
Front Brakes: Twin 320mm floating discs. Twin Brembo 4 piston 4 pad radial calipers. Radial master cylinder
Rear Brakes: Single 220mm disc, Nissin 2 piston sliding
Length: 2,115mm (83.3in)
Width (Handlebars): 780mm (30.7in)
Height: 1,250mm (49.2in)
Seat Height: 815mm (32.1in)
Wheelbase: 1,429mm (56.2in)
Rake/Trail: 23.5 degree/84mm
Dry Weight: 189kg (416lbs)
Fuel Tank Capacity: 18 litres (4.0 gal)
Performance (Measured at crankshaft to DIN 70020)
Maximum Power: 132PS / 131bhp / 97kW @ 9,250 rpm
Maximum Torque: 105Nm / 77ft.lbf @ 7,550 rpm
Colours: Blazing Orange, Jet Black, Fusion White
New Features
Specifications
Capacity: 1050cc
Compression Ratio
Gearbox: 6-speed
