2008 Yamaha R1 Specifications & Some Photos for discussion.
• 180 PS @ 12.500 rpm
• Yamaha Chip Controlled – Throttle & Intake
• 6-pot front callipers with 310mm discs
• Slipper clutch
Engine
Engine type Liquid cooled, 4-stroke, DOHC, 4-valve, forward inclined, parallel 4-cylinder
Displacement 998 cc
Bore x stroke 77.0 x 53.6 mm
Compression ratio 12.7:1
Maximum power without induction : 132.4 kW (180 PS) @ 12,500rpm with induction : 139.0 kW (189 PS) @ 12,500rpm
Maximum torque without induction : 112.7 Nm (11.5 kg-m) @ 10,000rpm with induction : 118.3 Nm (12.1 kg-m) @ 10,000rpm
Lubrication system Wet sump
Fuel System Fuel injection
Clutch type Wet, multiple-disc coil spring
Ignition system TCI
Starter system Electric
Transmission system Constant mesh, 6-speed
Final transmission Chain
Fuel tank capacity 18 L (3.4 L)
Oil tank capacity 3.83 L
Chassis
Chassis: Aluminium die-cast Deltabox
Front suspension system Telescopic forks, Ø 43 mm
Front travel 120 mm
Rear suspension system Swingarm
Rear travel 130 mm
Front brake Dual discs, Ø 310 mm
Rear brake Single disc, Ø 220 mm
Front tyre 120/70 ZR17MC (58W)
Rear tyre 190/50 ZR17MC (73W)
Dimensions
Length 2,060 mm
Width 720 mm
Height 1,110 mm
Seat height 835 mm
Wheel base 1,415 mm
Minimum ground clearance 135 mm
Dry weight 177 kg
You see they have used the blue bike and gold wheels, are they trying to copy the subaru's when they used the blue impreza and had gold wheels?
I dont know if its just me, but i personally just like either one or two colours. I dont seem to click with the three colours e.g. blue, black AND white. Blue and black would have been nice, but IMO the white breaks it up.
my mate just got his 08 r1 dynoed with same mods as my blade (slipon, pc3, filter) exact same power 163hp at wheel, will see if i can get a printout to compare....
