1 - 2 of 2 Posts
There may be folks around that will give you one if you look around, if not: I should have one in the shop and can give you the muffler+shield very cheap - can't quite give it away but a reasonably modest offer should work fine. IIRC they do weigh around 15 or 17 pounds when boxed up, so UPS is probably $20-25 at most depending on your zipcode. Send me a PM if you want one, and let me know if you need the exhaust valve cable as well.
1 - 2 of 2 Posts
