Hi. My dash elapsed timer does not always start and then stops intermittently. Probably only gets to 35 seconds on an hours commute. Any ideas where to start the fix ?
thanks.
Discussion Starter · #4 ·
Hi. Not the lap timer. Bottom right on the dash you can change the readings by pressing the mode button until elapsed time shows of each ride. The timer starts as soon as the wheel turns and should stop when it stops. Buy it doesn’t work properly. It starts randomly and stops after like 5 seconds even tho the ride is over an hour.
Discussion Starter · #5 ·
Yeah that’s it. But it never reads — — it’s just not Accurate. An hours ride can be recorded as 34 seconds for example. I was wondering where the pick up is for the timer ? Like front wheel or back ?
