1 - 2 of 2 Posts
Asking Price :$14000,00 OBO
For More Info #832-297-4033 Kevin
There some details about RIDE......
Description:454 BLOCK
TRW PISTONS .040 OVER 12 ½:1 COMPRESSION
EAGLE 3D RODS
EAGLE STEEL CRANK
ARP ROD BOLTS
LUNATI.692/.693 GROSS LIFT CAM
ADVANCE DURATION 320 DEGREES/326 DEGREES
DURATION @ .050” 278 DEGREES/281 DEGREES
LOBE SEPERATION 110 DEGREES/ 108 DEGREES
4200-8000 RPM
CAM RETARDED 2 DEGREES
MERLIN HEADS 1-043
TRW ROLLER ROCKERS
CRANE STUD GRIDLE
K MOTION VALVE SPINGS *950
2.25 X 1.80 VALVES
MARKWILLAMS REAR END (SPOOLED)
411 GEARS (RICHMOND)
STRANGE AXLES
MARK WILLIAMS PINION SUPPORT
WILDWOOD DISC BRAKES
TRANS KING POWERGLIDE
TURBO INPUT SHAFT 1:76 GEAR RATIO
TRANS KING TRANS BRAKE
MOROSO TRANS COOLER
HUGHS 5800 STALL CONVERTER
2 ½ GALSOROCO RADIATOR
ATI SUPER HARMONIC BALANCER
BARRY GRANT 400 GPH FUEL PUMP
MAXI FUEL REGULATOR
WEIAND WATER JACKETED INTAKE MANIFOLD (TEAM G)
HOLLEY 1050 DOMINATOR
MSD CRANK TRIGGER IGNITION
MSD 7 AL2 W/RPM SWITCHES
MSD DISTRIBUTOR W/WIRES
MSD COIL
MSD 3 STEP
AUTOMETER TACH W/MEMORY
DEDENBEAR THROTTLE STOP CONTROLLER
DEDENBEAR DELAY BOX
MOROSO ELEC. WATER PUMP & ELEC. FAN
ALUMINUM SKIN W/DUZ FASTNERS
PARACHUTE
WING
15 X 33.5 GOOD YEAR
(CENTERLINE ALUM. WHEELS IN REAR)
17 X 22.25
(CENTERLINE ALUM. WHEELS IN FRONT)
HARDWOOD SCOOP
HOOKER HEADERS
Also GOT NEW PLUGS N TIRES......
THERE are some recent pics.......
1320u.com - /members/neosin/images/dragster/2/
1 - 2 of 2 Posts
