1 - 9 of 9 Posts
when i attempt to up or down shift into 4rth gear I am rewarded with a nasty rattling sound/vibration that carries through the shift linkage. I'm not sure why she does not want to go into 4rth at any rpm.. any best guesses?
Best guess would be a bent shift fork.
Can you skip over fourth without any trouble?
Thnx bladeracer.. I can skip over 4rth without a problem in both directions.. When I accidentally hit 4rth things become a little unnerving.. almost sounds/feels like the tranny is trying to tear itself apart!
Yes, it's the dogs banging together but not getting quite close enough to mesh.
Does anyone know if I need to change all three of the shift forks at the same time, or just the offending one?
depending on how many miles are on your bike and if its ever been changed before, I would change the whole thing. Then, you won't have to worry about it for a long time to come. If you only change bits or pieces, then you are risking having some of the originals go bad on you and you'll end up dumping more money into it.
Thnxs Rokitt51, are you saying that I should replace both the mainshaft, countershaft, all the gears? The bike only has 20k on it.
When you get it apart you can check all the shift forks for wear and replace whichever are worn or bent.
Also inspect the gears and replace any with worn dogs or slots.
4th may well have the dogs rounded off if it's been playing up for a while.
1 - 9 of 9 Posts
