1 - 2 of 2 Posts
hi does anyone know wether the 600 carbs re jetted will work with the 900 motor (1995) and also the electrics and wiring cable etc the same or different
As a cluster, the spacing to the head is wider on the 900. The intake diameter is much smaller on the 600 too so you will need custom tapered boots. Finally, no amount of jetting is going to make up for the restrictive diameter of the 600 carb inlets for higher rpm where the 900 makes power.
1 - 2 of 2 Posts
