first you have to make sure where the noise comes from. get a long flat tip screwdriver and put it against the clutch cover while running and put your ear to the end of the screwdriver, will act like a stethoscope. move screwdriver to different parts of the motor and listen for the noise where it get loudest.
i had to replace the basket. if it is your clutch basket, take your clutch apart to where the basket is empty. with the basket empty try turning the basket by hand. it should not turn at all. if it turn it is bad.mine would turn back and forth about a 1/4 inch, not supposed to move at all. could be your problem, maybe its not. find out the area where the noise is loudest and go from there.
