Is it possible to put a 05-06 600rr forks or 929 front forks on a 94 900rr? I'm try to upgrade the front end to invert forks and 17 front wheel.
use 929 triples or 954 triples. and the whole rest of the front end. dont get a 600rr front end they are shorter as well as 1000rr front ends. but you need the 929 954 triples for sure. you can use the 929 triples and get a 1996-1999 gsxr forks or hayabusa forks brakes and wheels. they will slide right into the 929 triples.
i'm using a 954 full front end on my 94 900rr ( 954 triples, discs, handlebars, callipers, hugger, and a stock sp1 rim to complement the rear wheel as a 6-spoke)
slips right on, with some slight adjustments at the front discs... not an issue though.. good luck...
