Bit of superglue will sort that out :D
I would guess the end of the adjuster is worn, you would probably have to unscrew it and dress the tip with a file.
yep. i have no idea what that last part means.
just the tip!! OH THE TIP! :rotfl:
if i keep screwing it towards the front will it come off that way or the opposite? Yes im literally this slow that i need help unscrewing....a screw...
Looks to me like the cable is binding under the insulation. If it were mine I would take the idle cable off and lube it from both ends and see if it makes it better. :thumb:
