My 98 900rr is not charging enough,, well barley at all,Replaced the stator and the reg/rectifier, Fully Charged Battery the battery wont read over 12.2volts, at the red/white wire and ground AT the rectifier it will read up to 12.9 @5000rpms,, You use power at rectifier and ground at battery it will read 12.2, use power at battery and ground at rectifier it will read 12.9. Checked the ground at the battery, moved the ground, added a second ground, NOTHING IS WORKING, checked all the wires too and from everywhere everything looks good, the stator is putting out 50-60 AC volts at 5,000 rpms... Please help.... It's been at the local shop and he didnt figure it out either ... is there a short somewhere,, i got the biked trashed.. Could i have gotten a bad rectifier from Ricks??? anything will help.=(,,, thanks,,, dan
