I bought a similar directional, the LP Short Stalk V. I didn't use adapter plates, but put a couple washers between the end of the stalk and the outside of the place where the directional mounts to.
I also mounted the directional in the front hole, where the wiring originally went and ran the wiring through the original mounting hole.
Banned
That looks good. I guess i what i wanted is for the entire stem(stalk) of the turn signal to be from the outside of the fairing and kinda hide the original hole.
Maybe I'll plastic weld in some abs from the inside of the upper fairing, smooth it out with plastic filler, then drill a half inch hole in it's place:hmm: I want to repaint all the fairings anyhow.
Definately not putting down your idea, because that looks good.:clap:
