What all is needed to put 954 plastics on my 929?
will i only need a fairing stay for the front?
i already know i would need a 954 subframe for the tail
correct me if im wrong
You'll need the 954 headlight to fit the front plastics.
And I'm not sure if the duct covers will fit but I've never run duct covers on my 929.
and the tail doesnt bolt up, nor does the subframe.
Yes, you essentially need to cut the 929 and 954 subframes and weld the 929 mounting brackets onto the 954 frame so you can attach it to the frame.
so,if he needs the stay and the front headlight,i'm guessing he would need 954 side plastics,but it most likely won't bolt up to the 929 frame i'm guessing
Since he wants to put 954 plastics on a 929 he will need the 954 sides - that seems obvious.
As far as I know the 954 upper, sides and lowers attach to the 929 just fine.
But you can't mix and match the parts.
