1 - 1 of 1 Posts
Hi Guys,
I seem to have an issue with the clutch on my 929 - when the bike is coasting with the clutch pulled in if you blip the throttle then the bike jumps. It seems as if the clutch is still engaging ever so slightly. I've adjusted the clutch as much as I can using the adjuster on the lever. I've been told that I should loosen that off and then adjust it at the clutch end instead?
I also realise that the cable might have stretched too much but figured i'd try adjusting first. What do you think? Anyone got a link to a decent tutorial on adjusting it?
Thanks
Alex
1 - 1 of 1 Posts
