if you've done anything to the bike cosmetically like, different model fairings, swing arms, tails, etc post up pictures
atriot:
Errr NO.... it's a Duke tailpiece:rotfl:Honda has a 999?
:rotfl::rotfl:*Oops lol
Heres my baby VFR 800 swingarm, tail raiser, laser exhaust,GSXR 1000 K6 forks, gsxr 1000 steering damper, 1 piece tail with intergrated led tailight, 954 throttle bodies, bubble screen, dark candy apple paint.if you've done anything to the bike cosmetically like, different model fairings, swing arms, tails, etc post up picturesatriot:
Thanks......Im still using the 929 triple tree, it is a direct fit (GSXR Forks are about 6mm longer which i adjusted by having the forks come out abit higher than the CBR's position) As for the calipers i used the 929 wheel and 330mm disc so i had 10mm spacers made up and used longer bolts for the calipers so everything would fit (GSXR uses 310mm disc's). extended braided lines as the GSXR callipers sit a bit lower than the CBR's. handles and brakes great.....^ very nice bike, what triple trees are you runnig with the k6 forks? and did you have to do anything to get the calipers to work with the 929 rotors?
im very happy with it...and it's still a working project.....wow...lovely
Nooooooo, there are still thiings that i would like to do to it..like the engine..at the moment its all stock standard...i just clocked 157,600km on it. At some stage it will need a rebuild.Now your just showing off
