ok, so i got a new tank and my set up been apart since an accident in jule, im putting back together, need to know the fuel pump install, i did it with the banjo bolt bung on shift n brake side but the line looks folded when i install, please help, or send pix. which side does the line bung on the pump go on, brake or shifter side?
and
how does the fuel line go onto the tank?
one is a fuel overflow hose that goes to the bottom of the fairing,and the other is the actual fuel line to supply fuel to the motor .you can't really screw it up as the 2 hoses are different sizes
:plus1:....they should only fit one way. But if you are putting on a banjo bolt after removing, i would reccomend buying new crush washers to go on both sides of the fuel line. It will help drop the risk of a fuel leak
im actually inguiring about the banjo fitting on the fuel pump, does it go on shift side or the brake side, i know where all the other lines and electrical goes but also im wondering though, how the fuel line goes on the pump, the line has a metal fitting with a curve, does the curve point up, or down?
got it guys, sorry for the late replay but i got it on, thank you. however, after about a month now my fuel pump wint prime n t's fine. i checked the right clip on its fine, i checked the relay's their fine, the wires look fine, one day it just stopped wirking, the only thing i did was fix my tail light turn signal wiring
