can someone tell me if its ok to have m4 full exhaust system high mount + 2 brothers can on it
is it bad ?? will it sux ??? will i loose performance ????
anyone has an idea ??
Yes they do fit together.
You will loose some bottom end which you can correrct with a Power commander. The loss of bottom end is from the HETV valve removal, you will see a huge increase in 3/4 to full throttle and a huge improvement in throttle response in all ranges.
I do not recommend using this if you are not going to go the distance with the power commander and time to map it correctly.
