1 - 9 of 9 Posts
Hello,
I am planning on changing the gearing on my bike. I'm finding that I really don't need to keep the current tall gearing since during trackdays, I can't get the bike up to its top speed. Therefore, I thought I could sacrifice top end for better drive out of turns. Anyway, what do you all recommend? I've heard people do different things.
I like 15/44 and the stock chain will fit no problem. Many folks have gone to 15/45 also with good results. Stock chain may still fit with that combo,too, not sure. Either one of those will give you more pull out of the corners.
I went with a 110-link 520 chain and a 15/45 combo. I'd NEVER ride the bike with the stock 16/43 gearing again, it's so much better now. If anything, I'd consider 15/46, as I have plenty of adjustment left for an extra tooth out back. As it stands, my corrected top speed is 159.
I run a 520 15/44 gearing right now, you really can't go wrong with this setup. I'm going to test out the 520 15/45 gearing on the next trackday at Firebird East. I'll post up how I like it and if there is any difference at all. :D
I run 15 / 43.......still get the max top speed while increasing accelleration. Any drop in top speed from gearing is made up in the bike now being able to hit redline in 6th.
I was considering doing 15/45 as well and am wondering where the gearing will be. Where will 1st and second gear top out because the way I see it doing 80 in 1st gear is no fun. I'm looking for around 50 mph in 1st and 90 in second. Any recommendations?
520 15/45 here.. I wouldn't trade it for the world... Well, maybe not the world but an new 1RR might change my mind... :evilaugh:
Don't know about 1st, but on the rev limiter (~12200 rpm) in 2nd, she's showing 98 mph.
15/45, 520, SpeedoHealer.
Mine is 15/45 also. I like it. Pulls great, just be carefull in first if you have any other mods done. That first gear can be a doosey.
1 - 9 of 9 Posts
