1 - 19 of 19 Posts
Hi Guys,
Just joined the forum so first hello to everyone.
I've just bought a 929 in the hope of turning it into a track bike, I got the bike quite cheap with full service history & 30k on the clock. I have a 2009 R1 don't really want to take it to the track so thought I would try something else.
I test rode the bike on Saturday and immediately got caught in a thunderstorm and was so surprised how planted the bike felt even in bad conditions, The engine felt strong but seemed like it was holding back a little, but that could just be me being used to the power of the r1.
Couple of questions even though the bike has full service history is there anything I should check that could be missed on a normal bog standard service / Parts that are normally worn at this age and mileage.
Also I would like to improve the bike for the road / track so any recommendations of parts I can buy, I was going to but these parts straight away = K&N panel filter, Power commander, braided lines and do a full service at home ( plugs, oil & filter , fuel filter) The bike is completely standard and had new disks last year so was going to uprate the pads any recommendations?
Cheers
Craig
Congrats on the new to you bike dobbsy.
I've had my 929 for a few years and it's a fun bike to own. As for upgrades, there's a lot of mixed emotions and theories about changing to a k&n filter, there's some dyno sheets out there showing more power coming from the stock honda filter than a K&N.
Definitely a power commander, it'll help smooth out the bog on the bottom end. A full exhaust is a good idea, the aftermarket ones have straightened out the header quite a bit. The factory has quite a few bends to it.
Another mod, especially if your going to a track, is the GP style shift pattern. The cheapest and easiest way is to get a shifter from a VFR. It's a straight bolt on, and you get rid of all the linkage from the CBR.
I also put a quick turn throttle on mine. Of course I went the cheap route and bought a throttle tube for a '06 r6. Slides straight on, no messy modifying necessary and dramatically reduces how far you twist from idle to wide open.
Along with my power commander, I put on a dynojet quickshifter. Makes for easy effortless shifting and shifting at wide open throttle, makes you smile every time.
Lastly, I put on a set of throttle bodies from a cbr954. Their 2mm bigger and the injectors have 12 hole squirters instead of 4 hole from the 929. I haven't seen any huge improvement by making this latest change, but I drag race my bike and the weather hasn't been the best to get some good runs in, nor have I had any dyno tuning to get a proper map for the bike.
Good luck
Hi Guys,
Cheers
Craig
The servo motor, fuel pressure regulator and charging system are the common failures.
Another common problem is damage to the crankcase behind the stator cover as falling over even when stationary can break the cases. Also, the mounting knobs on the headlight and instrument cluster commonly break off in crashes.
Stick with the OEM air filter.
Pads I'd go OEM or EBC HH but whatever is easiest to source will likely work just fine.
Thanks for your posts guys, Will stick with the stock filter but will give it a good check over tomorrow once ive picked it up. Ive checked the crank case and cluster as they where broken on my mates one and there fine. Will wait until I get the bike and have a look at the shifter as I can't remember the set-up
The bike seems to be well looked after and im surprised as my r1 has a few marks here and there but this has none apart from some stone chips its either been extremely well looked after or had some panels resprayed. But looking through the service history nothing has been left to chance.
The only thing I forgot to mention was the rear tyre is getting low, what tyres suit this model ? I quite like to run dunlops on my yamaha...
Lose the flapper in the airbox. As for tyres, Pilot Power 2ct. LOVE them. Make sure to get the 190/55 for the back :D
There's a flapper in the airbox that is closed below 8000 rpm, mostly for noise and emissions. It effectively reduces the size of the airbox, and makes the bike run worse. It's EASY to remove - just a few screws. Leave the cable in the airbox (just let it flap - its fine), but remove all the plastic bits.
See this post for photos of what it should look like when it's done.
http://www.fireblades.org/forums/honda-fireblade/98503-flapper-mod-did-do-right.html
General consensus is that lowering a bike RUINS the handling .... Good call on the levers though. CRG shorty for the brake (long for the clutch) ... assuming you only use two fingers to brake :D
No worries saw them and wasn't sure. I have ASV levers both short on the Yam but will look up the CRG levers
Thanks Again :)
power commander, full exhaust , -1 front sprocket +2 rear sprocket and she will FLY :cheers:
I put a lowering link on my 929, but it's primary purpose is go as fast as possible in a straight line for 1320feet.. Although it looks cool.
Hey that looks familiar :smilebig:
But yea, lift up the gas tank, open up the airbox underneath, remove the air filter and you'll see the flaps underneath. Once you remove those, replace the filter, close everything up, and youre done. Takes 15-20 minutes tops
Discussion Starter #14
Thanks for all your posts.
Will remove the flapper tonight and post a couple of pictures of it, Weather doesn't look too good at the moment but hopefully will clear up. wont bother with the lowering kit, I changed the front sprocket on my old 675 and made the bike pick up so much nicer think it would have lost a bit of top-end tho. Will start looking into get some sprockets now, whats the standard tooth and both front and rear just so I know not to buy a standard one.
929 stock is 16/42.
16/43 in the US.
Looks sound and a good choice of bike.
Welcome to the .org, we're practically neighbours!
P.s. How come you'v got a picture of my wife's arse in your album?
Discussion Starter #18
haha. just picked it up, really happy long mot and tax. Nice and clean no sign of respays etc will start to strip it apart at the weekend the wife has just reminded me that I have to paint the spare bedroom...oh joy
1 - 19 of 19 Posts
