Anyone found a reference for what temperature the radiator fan should turn on?
Like all water-cooled engines the fan should come on just after boiling point - around 102C.
water under pressure won't boil at 100c btw :D
Yes, I know :)
Boiling point as a constant though is 100C at sea level.
Under cooling system pressure it's slightly higher, hence the "just after boiling point" statement.
Discussion Starter · #7 ·
Thanks guys. I finally found the reference in the service manual.
Fan motor switch
Start to close (ON) 98-102 C (208-216 F)
Stop to open 93-97 C (199-207 F)
Strange because mine use to to turn at about 195-198 F.
