I went out a few weeks ago to go to work on the bike and when I turned the key the headlight relay started buzzing ( I had my hi beams on when I parked it). But The high beam wasn't on. I turned it off but have the cluster was still dim? I tried the turn signals and the turn signal relay started buzzing and the lights did not work correctly? I replaced the relays and still the same thing. I check the turnsignals bulbs, ok. I checked the fuses, ok. Anyone have this happen before?
PS I have two new relays for sale!
Yep. I just don't know what's causing it to buz? The same with the Turn signal relay? I took the left control apart but the high beam switch isn't serviceable. There was a clicking sound in the right side of the tail section when I cycled the high beams on and off and got better for a bit but then got worse and the clicking wasn't as loud? I know this week I'm going to clean the starter switch and look at the high beam switch?
:rotfl: Awesome !! :D
