front forks.$50 left is slightly bent right is good top adj broken. rotors.$90. tirehugger. $20 has cut were hole is. lower fairing stay.$30 a little swisted but should work. left&right inner plastics $30. wire harness$65. start switch$15 housing not good. left rear set$15. left air tube$10. gas tanks.$20 each no leaks. front sprocket cover$10. rear chain gaurds $15.left air tube cover.$20. Stator Cover.$30 does not fit all the way onto 929 motor and stator bolt patter smaller than a 929 pattern. will refund you money if it does not fit. [email protected]
how much for the stator cover, is it factory or repainted?
Also do you have both sides of the ram air covers or just the left?
$30 for stator cover but is does not fit 929, and i only have left air cover, oh and stator cover has been repainted.
